40
Not saving the Schema
I can't get the Data Schema to save.
I have the UltraWinGrid on my form.
Go into the designer.
Select Basic settings -> Data Schema
Click on Manually Define Schema.
 Place a few rows down.
ie CostId, DataType = System.int32, DefaultValue = System.int32 (0)
Amount, DataType = System.decimal, DefaultValue = System.Decimal (0)
I define others as decimal.
Click Ok, and it asks if you will be NOT be supplying a datasource at Runtime/you will be supplying a datasource at Runtime.
I select the "I will be supplying a datasource at runtime"
Hit Ok,
I get the summation signs on my column headers.
If I hit "Apply" then "Ok"
The summation signs disappear.
if I try to go back into the designer, none of the datatype information is retained. It goes back to String and dbnull for the data type and default. Now this may not be the cause of the problem that I'm really having.
I have a summary on the Amount column. If I run it, it works the first time the window get's a datatable. The second time it get's a datatable, it gives me a null reference exception in the control itself.
Sometimes it will work for a few runs, then all of a sudden a Null Reference exception and it gives the stupid message about needing a "new"
