625
ProgressBar grid column editorcontrol does not render
I have two grids bound to seperate BindingSource objects.  The BindingSource objects are bound to two seperate BindingList<T> objects.  The idea is that in Grid A, the user can check a box called "Watch" will add the underlying business object to the BindingList<T> bound to Grid B.  Both grids have the same schema which includes a percent complete column.  Each grids has its PercentComplete column's EditorControl set to a seperate instance of UltraProgressBar (so there are two of these).
If a row in Grid A was %Complete = 50% then the cell shows 50% and the visual feedback shows the cell 50% filled.  If the user checks the Watch checkbox, the object is added to the bindinglist of Grid B and displays in Grid B as a new row.  The problem is that the %Complete cell for the row says 50 with no visual feedback from the progress bar.  Its as though the EditorControl reference is lost.  What am I doing wrong?
Paul
