3550
Error on opening samples
When we try to open the forms of the samples in design mode, we get an error message.
One or more errors encountered while loading the designer. The errors are listed below. Some errors can be fixed by rebuilding your project, while others may require code changes.
No license information found
Hide
at Infragistics.Shared.UltraLicenseProvider.GetDesignTimeLicense(Type type, Object instance, Boolean allowExceptions, UltraLicenseBaseAttribute licenseAttribute)
at Infragistics.Shared.UltraLicenseProvider.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions)
at System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey)
at System.ComponentModel.LicenseManager.ValidateInternal(Type type, Object instance, Boolean allowExceptions, License& license)
at System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
at Infragistics.Win.UltraWinGrid.UltraGrid..ctor()
But we installed Infragistics, and we work with it with no problem.
