When I move a column header into the GroupBy box, the new Grouped Band does not have a TemplateAddRow. I have tried to enable it with
Private Sub _Target_InitializeGroupByRow(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeGroupByRowEventArgs) Handles _Target.InitializeGroupByRow With e.Row.Band.Override If .AllowAddNew = AllowAddNew.Default Then .AllowAddNew = Infragistics.Win.UltraWinGrid.AllowAddNew.TemplateOnBottom End If End WithEnd Sub
But the row does not appear. It does show in the non-Grouped bands. Is there any way to get this row while Grouped?
ThanksDavid Gauerke
Mike,
I have made a feature request using the link that you provided. In the meanwhile I guess that the only thing to do about this is to add a new row to the datasource instead.
Also, I would like to thank you for taking the time to provide support here at the forum. These posts have really helped me out in using your excellent product.
Thanks!
John
The grid does not currently support this. You should Request a Feature or Component from Infragistics.
I also have the same question.
I have a grid that I group in code by adding a column to the SortedColumns collection. After that I can't add a new row. What is best practise to accomplish this?
I've the same question. I would like to use the groupby feature for visualisation of the data, but when I use this, the TemplateAddnewRow disappaers. I need to have this addnew row because users must be able to add new rows.
thx
Wim
