Hello guys,
I am gonna insert some controls into AddNewBox, like some buttons or images. I tried to use CreationFilter to achieve this.However, I can never see controls I added.
In my CreationFilter:
public void AfterCreateChildElements(Infragistics.Win.UIElement parent)
ButtonUIElement btn1 = (ButtonUIElement)parent.GetDescendant(typeof(ButtonUIElement));
parent.ChildElements.Add(btn1);
in my form:
grid.DisplayLayout.AddNewBox.Hidden = false;
grid.DataSource = lsResult;
AddNewCreationFilter addNew = new AddNewCreationFilter();
grid.CreationFilter = addNew;
When I debug I can see the buttonUIElement control is added, but it never appears on the UI.
Any idea on this?
Cheers,
Elton
Hi Elton,
It sounds like make you should be using the TemplateAddRow. Set the AllowAddNew property on the Override to TemplateOnBottom and the grid will give you an AddNew row at the bottom of every row island automatically.
Thank you for the reply Mike,
I am actually looking for a way to insert a new "row" like part into the bottom of each levevl/group of grid, and put my own controls onto that part.
I was trying to use AddNewBox but I notice it's only available in level 1. Coz the AddNewRow appears on each level, so I am trying that for now.
I also think the FilterRow could be another option.
Just wonder which way you think is easy to archieve this.
Need your advice.
It's hard to say for sure with just a code snippet, but one thing I notice is that you are not setting the Rect on the button element. So my guess is that is has a size of 0,0.
