Happy new year 2009 to everybody !
I'm experiencing an issue with Visual studio 2008 ans Ultracombo's datasource.
I've made a sample program to reproduce the problem.
Here's the example :
ObjectA is composed of a list of ObjectB.
If you set ObjectA as datasource of Ultracombo it will works, but now if you edit ObjectB and add a reference to ObjectA (uncomment my line) then Visual Studio will hang/freezes until you kill the process when trying to edit the combo or execute the program.
It seems that Infragistics controls doesn't like recursive calls within a datasource as it seems to add the Object B properties as columns for the UltraCombo ? (so A call B which call again A, then B, ....)
I don't know what to do as I need to be able to set A as datasource in my combo to display some of the columns and hide the others.
How doest Ultracombo datasource works ? How can i by the way add a second band in the same combo with a datasource ?
Please advice !
Yannick said:Do you know if a BR has already been submitted following the post you pointed at ?
Yannick said:By the way, I was wondering if there was a possibility to perform this scenario in ultracombo : Band A - 3 columns - List of items coming from a list of object of type A Band B - 5 columns - List of items coming from a second list (not linked to first) of Object of type B I can't see how can I achieve this ? (if even possible !)
Yannick said:Else my needs is to have an UltraComboEditor with possiblity to add manually items but these items should be displayed within a Grid as there's many informations to display to let the user choose the right item.Maybe an idea for a new component ?
If you want to simulate "manually" adding items to WinCombo (as opposed to WinComboEditor), use a DataTable or a WinDataSource to which you add the items you want shown in the control.
Thanks for your anwser,
The following post and its accompanying thread provides information that is likely related to your issue:http://forums.infragistics.com/forums/p/13420/52976.aspx#52976
