Hi All,
I am using the UltraDockManager to dock three user controls. The dockable control pane of all these three user controls are set as MdiChild.
I am trying to save the settings of the dock manager by setting the SaveSettings property to true. The saving format is XML.
The settings are restored properly when the controls are either docked or floating. But when the controls are there as a MdiChild with titlebar and controlbox, while closing the application, then it is not restored properly. An extra empty window appears for each MdiChild which has only Titlebar and controlbox apart from the proper Mdichild Window.
Can someone please help me on this?
Thanks in Advance
Manikandan
This sounds like a bug. I would recommend submitting the issue to the support group: http://es.infragistics.com/gethelp.
