Double clicking on a separator between two column headers in a multicolumn WinTree resizes the columns but it does not seem to be triggering any event. Since this resize is triggered by user I was assuming that AfterNodeLayoutItemResize event would fire, but this does not seem to be happening. Is there any other event? Or should'nt AfterNodeLayoutItemResize be triggered in this scenario. Please suggest.
spm
Was there a resolution to this issue? I have the same issue and I'm working on a newer version. Is there another event or work around that I can use?
Do you have the latest Hot Fix? I could be wrong, but I vaguely recall something like this being fixed.
If not, you should report this to Infragistics Developer Support so they can check it out. Get Help
Is any one facing similar problem?
