Dear All:
there is a column which ColumnStyle is DropDownValidate in the ultraWinGrid , and this column is binded a ultradropdown.
Now I want to help as below:
1、 let this column Only accept from the ultradropdown.
2、if this column is not from the ultradropdown, don't let the system messagebox show out automatically, and if the data is not in the ultradropdown, can't let the user move out from this column.
Thanks in advanced
Tramp
Dear Matt:
According to your suggestion, it is ok now.
Thanks for your help.
Tramp,
I'm not entirely sure what you are trying to do here. If you want to completely limit the user's selection to the column, then I would suggest that you use the DropDownList style on the column instead of the validate. If I recall correctly, the Validate portion of the style will prevent the user from exiting edit mode if the item isn't in the list, which you could also do by handling the BeforeExitEditMode event yourself.
-Matt
Who can help me on above issue?
Many Thanks!
