I'm using NetAdvantage 6.3 version to develop our Window Form application. Now I'm trying to write test code using Microsoft UI Automation. But I'm not sure whether Infragistics supports this. Please help me if anybody aware about this . . .
I can't really discuss future product plans, and I honestly do not know. I am not aware of any such plans, though.
You can Submit a feature request to Infragistics.
How I understood no support from Infragistic's components to UI automation. I have another question to you:
In the near future Infragistic's, do you think that Infragistics will support UI Automation? I'm asking you because our projects are Infragistics 7.2 and I want to implement an automate tool for testing.
Best Regards,
Bogdan Mitrea
White, an open source code, supports access of Infragistics controls using MS UI Automation indirectly.
For example, White is developed to access the DataViewGrid control. Since the source code is available, it can be customised to access the UltraGrid control.
For more info, please check http://www.codeplex.com/white
Thanks & Regards,
Kannan
Thanks for the reply .. . . When I checked, I could get the patterns for some basic controls like UltraTextEditor, UltraButton etc but not for the controls like UltraGrid, UltraTree. Is there any workaround to test the Infragistics controls using Microsoft UI Automation ? If so please let me know. Thank You !
"IGMikeS" wrote in message news:64884@forums.infragistics.com... Hi Kannan, No, the Winforms controls do not support Microsoft UI Automation. Mike SaltzmanR&D EngineerInfragistics, Inc. http://forums.infragistics.com/forums/p/17827/64884.aspx#64884
Hi Kannan,
