585
Remove Display of Column Header
I would like the tree to not display the column header at all. How do I do this? It is bound to a BindingSource object. Thanks!
  • 469350
    You need to set the LabelPosition on the ColumnSet to None. How you do this depends on whether or not the tree is bound at run-time or design-time and when the column set gets created.
    If you are binding the tree at run-time, then you could do something like this:
            private void ultraTree1_ColumnSetGenerated(object sender, Infragistics.Win.UltraWinTree.ColumnSetGeneratedEventArgs e)
                e.ColumnSet.LabelPosition = Infragistics.Win.UltraWinTree.NodeLayoutLabelPosition.None;
