I want to display the following details in a Grid.
Col1 Col2 Col3 Col4 Col5 Col6
$25.00 $20.00 $15.00 $10.00
$50.00 $ 8.46 $ 7.00 $20.00
$ 6.00 $ 5.00 $10.00 $ 9.00
Sub Total: $ 81.00 $33.46 $32.00 $39.00
(e.g. 25 + 50 + 6)
Total: $104.50 $33.50 $32.00 $39.00
(33.50 + 32 + 39)
The Sub Total equals to Sum of each column. For example: Sub total for Col3 = 25 + 50 + 6 = 81. Same applies for other columns
The Total displays a diffrent story. it will be equal to Sum of Colums (excluding Col3) which are already summed and with some rounding up with a Col4
e.g. Total = RoundUp(Col4) + Col5 + Col6 = 104.50
I have added the following coding for UltraGrid:
this.UltraGrid.DisplayLayout.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.False;
| Infragistics.Win.UltraWinGrid.SummaryDisplayAreas.GroupByRowsFooter)));
this.UltraGrid.DisplayLayout.Override.SummaryFooterCaptionVisible = Infragistics.Win.DefaultableBoolean.False;
this.UltraGrid.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.UltraGrid_InitializeLayout);
Now here are my questions:
1. How can I display the "Sub Total" caption without the " Grand Summaries"
2. And to display the Sum for each column for Sub Total with the Format of $ 0.00 (currenctly it is 12.28193)
3. How to create a customized summary row with the Caption "Total" and to set a column (Probably under Col3 after SubTotal as show above) the calcuation = RoundUp(Col4) + Col5 + Col6 using a formula with ultraCalcManager1
I hope u cleary understand my points. PLease let me know if anyone need clarifications.
URGENT HELP NEEDED!!
Thanks in Adance!
nw
Thanks alot Mike. Problem solved. Sorry for the late reply.
Nw
It's really hard to tell just from code snippets, but I will take a shot.
nomiw said:1. How can I display the "Sub Total" caption without the " Grand Summaries"
I'm not sure if this is possible. There's a SummaryFootCaptionVisible property, but the property is on the Override and so affects the entire band, so I don't think you can remove one without removing the other.
nomiw said:2. And to display the Sum for each column for Sub Total with the Format of $ 0.00 (currenctly it is 12.28193)
Use the DisplayFormat on the SummarySettings.
nomiw said:3. How to create a customized summary row with the Caption "Total" and to set a column (Probably under Col3 after SubTotal as show above) the calcuation = RoundUp(Col4) + Col5 + Col6 using a formula with ultraCalcManager1
I'm not sure I understand the question. You can't create an extra summary row. But maybe you can just as a new summary and use the DisplayFormat to have it show something like "Total = xxx"
