I'm using NetAdvantage 8.2 and I've noticed a problem with the toolbars when a form is resized and there's no longer enough room to display all the tools.When this occurs, a small button is added to the right of the toolbar for displaying a popup menu containing the missing tools. However, this popup menu is empty! It only seems to work when there's 1 extra tool, as soon as there's more then 1, the popup menu becomes empty and therefore the tools are inaccessible.
Any help with this issue would be greatly appreciated, thank you.
Note : In my tests, the "overflow" tools were ButtonTools, and the ViewStyle of the toolbar manager is Office2007
This issue has been reported and fixed. Try downloading the latest hotfix to see if it addresses your issue. If not, it could be a different bug and I would recommend submitting it to the support group: http://es.infragistics.com/gethelp.
