220
How to allow column insert but not column update?
We are using UltraWinGrid. In a row, there are certain UltraGridColumn that the user is allowed to edit and some not allowed to edit. The user is allowed to add a new row though. However, when we use CellActivation = Activation.NoEdit, the column is also uneditable in the addrow. How can we allow a column to be editable in the addrow but become uneditable in the other rows?
  • 17259
    You can check the row type in the BeforeRowActivate event and override the column behavior:
    private void ultraGrid1_BeforeRowActivate(object sender, Infragistics.Win.UltraWinGrid.RowEventArgs e)
       if (e.Row.IsUnmodifiedTemplateAddRow)
          foreach (var cell in e.Row.Cells)
             cell.IgnoreRowColActivation =
    true;         cell.Activation = Infragistics.Win.UltraWinGrid.Activation.AllowEdit;
       else
    false;
