570
Bug in class UltraDataSource, method AddRange(...) ?
Hi All !
Szenario:
By pushing a button a UltraCombo should be filled via a UltraDataSource (which is associated to the UltraCombo).
Problem:
Using UltraDataSource's "AddRange" method does not fill the UltraDataSource and therefore the UltraCombo.
By the way:  using the UltraDataSource's method  "Add"  works fine.
e.g. this.ultraDataSource1.Rows.Add(new object[ { ((object)("1")), ((object)("Ralf"))});
Source code:
I have simplified the code like this:
//Form1.Designer.cs
private void InitializeComponent(){
 UltraDataColumn ultraDataColumn1 = new UltraDataColumn("Name");
 UltraDataColumn ultraDataColumn2 = new UltraDataColumn("Nr");
        ultraDataSource1 = new UltraDataSource(this.components);
        ultraCombo1 = new UltraCombo();
// ultraDataSource1
this.ultraDataSource1.Band.Columns.AddRange(new object[ {
     ultraDataColumn1,
     ultraDataColumn2});
// ultraCombo1
this.ultraCombo1.DataMember = "Band 0";
this.ultraCombo1.DataSource = this.ultraDataSource1;
ultraGridBand1.Columns.AddRange(new object[ {
             ultraGridColumn1,
             ultraGridColumn2});
this.ultraCombo1.DisplayLayout.BandsSerializer.Add(ultraGridBand1);
this.ultraCombo1.DisplayMember = "Name";
this.ultraCombo1.ValueMember = "Nr";
 // Form.cs
 private void ultraButton1_Click(object sender, EventArgs e)
             this.ultraDataSource1.Rows.AddRange(new object[ {
             new Infragistics.Win.UltraWinDataSource.UltraDataRow(new object[ {
                         ((object)("Nr")),
                         ((object)("1")),
                         ((object)("Name")),
                         ((object)("Ralf"))}),
                         ((object)("Nr")),
                         ((object)("2")),
                         ((object)("Name")),
                         ((object)("Claus"))}),
                         ((object)("Nr")),
                         ((object)("3")),
                         ((object)("Name")),
                         ((object)("Georg"))}),
                         ((object)("Nr")),
                         ((object)("4")),
                         ((object)("Name")),
                         ((object)("Monika"))})});
Any advice or ideas you might have, would be very welcome. Thanks in advance !
Kind regards,
Claus
  • 469350
    Verified Answer
    Hi Claus,
        The AddRange method does not show up in Intellisense for a reason. It's intended to be used for the Deserialization of the control. This method is intentionally hidden because you are not supposed to use it in your code. The AddRange method isn't even listed in the Online documentation for the same reason.
