490
Hiding repeated column headers in banded grid
I have a grid with 2 bands. The parent band should display the column headers, but the sibling band should not. This was easy to configure. The problem I am having with this configuration is that when the sibling band is expanded, it causes the column headers for the parent to be shown again. How can I force the parent band of the grid to only show the column headers one time only (at the very top of the grid control)?
  • 37774
    Verified Answer
    I assume that you're using the HeaderPlacement property on the Override object.  If this is the case, what value are you using?  I would think that HeaderPlacement.OncePerRowIsland would work for the main band, since there is only one row island for that; the comments even specifically mention that if a visible child is expanded, the next sibling will still not display the row headers.
    -Matt
