130
Ribbon application popup menu always expanded when displayed
What property should i use in order that the ribbon application menu should be opened in expanded mode (without scrolling).Currently when pressing button in the upper left corner of the ribbon control, the dropdown menu is opened but not all items are visible (Use scrolling).
  • 44743
    Verified Answer
    The ApplicationMenu should display as many menu items as it can based on your settings and screen size. It should only scroll if there is not enough room to display all items. That said, there was a bug recently that certain view styles other than Office2007 would cause the ApplicationMenu to need to scroll even though there was plenty of room for the items. If you are using a non-Office2007 view style and this is happening to you, you can submit the issue to the support group and reference issue BR29037 to be notified when the hotfix is released: http://es.infragistics.com/gethelp.  Otherwise, if you are using the Office2007 view style and all menu items should have enough room to display, you should also submit the issue to the support group.
