575
Save recurrence field at database
hi
i use the Databinding  with the ultraCalenderInfo and use Custom Appointment Dialog with recurrence my need is to save the recurrence data at the DB field as "String" and actully i need the Description of the Recurrence to save it at the DB .. i know about the Byte[ which i can save it but i need to use string cuz i send my paramters from the application as an XML and i saw that Byte[ will confuse me .. so My my Question is if i save the Description of the Recurrence is the Data can bind by this description by the
this.uNotificationInfo.DataBindingsForAppointments.RecurrenceMember = "Col_Recurrence";
where "Col_Recurrence" is nvarchar col in the SQL DB.
and if not what is the other types that i can save my Recurrence in the DB rather than Byte[
thank alot
  • 69832
    I'm not sure if I understood this post but the AppointmentRecurrence data is serialized as a byte array, so the corresponding database field has to support that type. The SQL Server 'varchar' type can be used for byte arrays.
