1483
Programatically created dockareas are forgetful
 I programatically create a tabbed dockable group pane with 2 tabs.  After these tabs are created and displayed. I grab a tab and float it.  Once floated I double click on the floated dock in order to send it back from where it came.  When it returns to the dock it returns to a new group not from the tab group.  If I manually put it back into the correct tab group then perform the same float and dock operation all is well.  Is there something I can do when manually creating a tab group to have the panes remember where they came from when floated?  Heres my code to create Groups and Panes:
protected static DockableGroupPane CreateTabDockableGroupPane(IControlDefinition definition)
DockableGroupPane dockGroupPane = new DockableGroupPane();dockGroupPane.ChildPaneStyle = ChildPaneStyle.TabGroup;
dockGroupPane.GroupSettings.TabLocation = ConvertToLocation(definition.TabOrientation);
dockGroupPane.Size =
new Size(definition.Width, definition.Height);
dockGroupPane.Text = definition.Name;
return (dockGroupPane);
protected virtual void AddControlToGroup(DockableGroupPane groupPane, IControlDefinition definition)
if (definition != null)
DockableControlPane dockableControlPane = new DockableControlPane();
dockableControlPane.OriginalControlBounds = new Rectangle(definition.X, definition.Y, definition.Width, definition.Height);
dockableControlPane.Size = new Size(definition.Width, definition.Height); Control control = CreateControl(definition);
dockableControlPane.Control = control;
dockableControlPane.Text = definition.Name;
groupPane.Panes.AddRange(
new DockablePaneBase[ { dockableControlPane });
Bill
