180
Root location
I created a navigation bar.Now i need to add Mycomputer as the root location of the navigation bar and i also need the sub directories
I am new to this infragistic control
My code is as below
private void Form1_Load(object sender, EventArgs e)
// The text that WinNavigationBar will use when parsing
this.ultraNavigationBar1.RootLocation.DisplayText = "Local Disk (C:)";
// the full path of a child location (or itself).
this.ultraNavigationBar1.RootLocation.Text = "C";
private void ultraNavigationBar1_InitializeLocations(object sender, InitializeLocationsEventArgs e)
// Populate an array of DirectoryInfos with the
// subdirectories of the parent location's path.
DirectoryInfo[ dirs = new DirectoryInfo(e.ParentLocation.GetFullPath(FullPathFormat.EditMode) + "\\Anil\\").GetDirectories();
// Loop through each subdirectory...
foreach (DirectoryInfo dir in dirs)
// ...add a new location to WinNavigationBar.
// The subdirectory's full path will be the key
// and the name will be the Text.
e.ParentLocation.Locations.Add(dir.FullName, dir.Name);
private void LoadFilesAndFolders(string path)
// subdirectories of the selected location's path.
DirectoryInfo[ dirs = new DirectoryInfo(path + "\\").GetDirectories();
// Get the files associated with the selected location.
FileInfo[ files = new DirectoryInfo(path + "\\").GetFiles();
// Clear the previous location’s items from WinListView
this.ultraListView1.Items.Clear();
UltraListViewItem item = null;
// Populate WinListView with folders and files.
item =
this.ultraListView1.Items.Add(dir.FullName, dir.Name);
item.Tag = dir;
// At this point, you can assign an image
// to the folder items with a line of code
// similar to the following...
//item.Appearance.Image = this.imageListLarge.Images[0];
foreach (FileInfo file in files)
item =
this.ultraListView1.Items.Add(file.FullName, file.Name);
item.Tag = file;
private void ultraNavigationBar1_SelectedLocationChanged(object sender, SelectedLocationChangedEventArgs e)
this.LoadFilesAndFolders(e.SelectedLocation.GetFullPath(Infragistics.Win.Misc.FullPathFormat.EditMode));
private void ultraListView1_ItemDoubleClick(object sender, ItemDoubleClickEventArgs e)
if (e.Item.Tag is DirectoryInfo)
this.ultraNavigationBar1.NavigateTo(e.Item.Key, true);
else if (e.Item.Tag is FileInfo)
System.Diagnostics.
Process.Start(e.Item.Key);
I am getting an error in this line
as Could not find a part of the path 'C:\Users\Anil\Documents\Visual Studio 2008\Projects\NavigationBarusingInfragistic\NavigationBarusingInfragistic\bin\Debug\C\Anil'.
what modification should i do with the code
Please help me
