I found this in another post. "If you are using OutlookExpress style then you can't apply an image to a node. The node displays using Columns. So you would have to put the image into a cell of the node."
What can I do to allow images with text without making a separate column? I'm trying to create a file explorer like app which displays a tree structure with columns ( e.g. file type, size, date created, etc. ) and also have folder and file icons displayed next to the file or directory name.
This is a MUST requirement, so I need to find a solution.
Please help.
Jason
Spot on, thank you very much. I actually discovered this almost by accident late last night, this confirms the solution. The LayoutInfo is much underrated imho!
Thanks again, Tom
Hello Tom,
You should resize the cell in order to be able to view such image in it:
ultraTree1.ColumnSettings.ColumnSets[0].Columns[0].CellAppearance.Image = SystemIcons.Asterisk.ToBitmap(); ultraTree1.ColumnSettings.ColumnSets[0].Columns[0].LayoutInfo.MinimumCellSize = new Size(32, 32);
Is this what you are after?
Hi sorry to drag up an old question, but I have not been able to successfully use a 32x32 image here. It simply resizes to 16x16.
Also using tree.Override.ImageSize = Size(32, 32) does not work.
Any ideas?
Thanks, Tom
cell.Appearance.Image = myImage
