135
Singleton MDI Children?
Say I have an UltraExplorarBar on the left in the MainForm. On the bar there's 3 items, customer A, B, and C, and the MainForm acts as MDI Parent. In the project I have a CustomerForm so that if you click on the item on the bar, a customer form pops up on the right in MainForm. The problem is, how can I ensure that there's only one CustomerForm pops up for customer A, if user clicks the customer A icon serveral times? It looks like that I can't use singleton pattern on the CustomerForm becuase serveral customers share the same form object.
What whould be the best way to implement the? Is there any build-in thing in Infragistics that can help with this?
  • 145
     Use this method ..may be usefull for u ...i created based on form text ...replace with form name (MdiChildren[i].name) ...like that..
    if (ActivateThisChild(formText) == false) then open form logic ...
    private Boolean ActivateThisChild(String formText)
    int i;
    Boolean formSetToMdi = false;
    for (i = 0; i < this.MdiChildren.Length; i++)
    // loop for all the mdi children
    if (this.MdiChildren[i].Text == formText)
    // find the Mdi child with the same name as your form
    // if found just activate it
    this.MdiChildren[i].Activate();formSetToMdi = true;
    if (i == 0 || formSetToMdi == false)
    // if the given form not found as mdi child return false.
    return false;
    else
    return true;
  • 19380
    We don't provide any easier way to do what you are after.  If you are using VB, the singleton form pattern is built in.  In C#, you can enumerate the forms and MdiChildren collection and check to see if the form is loaded before you create a new instance of it.
    Let me know if this helps or if I misunderstood what you are after,
    Jason
