I have a situation where the ultragrid is bound to the DataTable where the DataTable is created using a Text File which is Tab Delimited i.e. columns are identified by Tab and rows are on subsequent lines.
What I want is that if I have a Number Column, and there is a null value for a cell, it should display "NULL" on the cell, how can I achieve this if there is any possibility.
Talha Muhammad
Hi Talha,
You can do something like this:
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Bands[0].Columns["Number"].NullText = "NULL"; }
