Is there any way to smooth out the animation?
It doesn't seem to matter what AnimationSpeed setting is used.
I would recommend submitting a sample reproducing this issue to the support group: http://es.infragistics.com/gethelp.
Hi Mike,
In our application we have number of user controls which are updated (painting required) frequently. I have seen the that during auto hiding, the some text drawing is not smooth. Some pixels are not cleared.
It appears to be related to the complexity of the controls that are not on the docked pane.
As a test, I removed the controls on the main area of the form and it closed just fine.
I will submit a sample as time allows.
I guess it depends on how complex the layout and display of the grid is, but it's possible it is a bug. I would recommend submitting a sample demonstrating the issue to the support group if possible: http://es.infragistics.com/gethelp.
It depends on your definition of "many controls".
Are there any painting events I can turn off?
