1233
Grid Columns and Rows not accessible
Attempting to create a multi-select drop-down, using an ultratexteditor, a dropdowneditorbutton, and an ultragrid, I am having trouble accessing the rows and columns of the grid.
 I have tried adding unbound columns, using an ultradatasource, and numerous other approaches.  Currently, I created a form with a grid and an ultradatasource, and then ported the designer code into my control initialization.
 No matter what I try, _grid.Bands[0].Columns.Count is always 0.  _grid.Rows.Count is also always 0.  However, the dropdown grid does have rows and columns, and the multi-select feature works well.  I need access to the columns so that I can change the column header.  I tried accessing via rows to access cells[0].Column.Header.
I have also reflected into the code to try to determine if a flag is set during initialization that would prevent the property collections from initializing, but I can't seem to find anything.
Can you please help me understand what I might need to do to access the grid columns?  I am posting the initialization code, which is a little lengthy.
private DropDownEditorButton _dropDownEditorButton;
private BaseGrid _grid;
private void InitializeComponent()
_grid =
new BaseGrid();
_grid.InitializeGrid();
_dropDownEditorButton =
new DropDownEditorButton { Control = _grid };_dataSource = new BaseDataSource();
_grid.DataSource = _dataSource;
((ISupportInitialize)(_grid)).BeginInit();
((ISupportInitialize)(_dataSource)).BeginInit();
// create data bands and columns
var selectedDataColumn = new UltraDataColumn("Selected") {DataType = typeof (bool)};
var displayDataColumn = new UltraDataColumn("DisplayMember") {DataType = typeof (string)};
_dataSource.Band.Key = "Items";
_dataSource.Band.Columns.AddRange(new object[{selectedDataColumn, displayDataColumn});
var selectedGridColumn = new UltraGridColumn("Selected");selectedGridColumn.Header.Caption = "Selected";
selectedGridColumn.Header.VisiblePosition = 0;
var displayGridColumn = new UltraGridColumn("DisplayMember");
displayGridColumn.Header.Caption = "DisplayMember";
displayGridColumn.Header.VisiblePosition = 0;
var band = new UltraGridBand("Items", -1)
ColHeadersVisible =
true,
IndentationGroupByRow = 0,
IndentationGroupByRowExpansionIndicator = 0,
ExcludeFromColumnChooser =
ExcludeFromColumnChooser.True,
Override =
AllowRowFiltering =
DefaultableBoolean.False,
AllowRowLayoutColMoving = Infragistics.Win.Layout.GridBagLayoutAllowMoving.None,
BorderStyleRow = UIElementBorderStyle.Solid,HeaderPlacement = HeaderPlacement.FixedOnTop
band.Columns.AddRange(
new object[ { selectedGridColumn, displayGridColumn });
_grid.DisplayLayout.BandsSerializer.Add(band);
_grid.DisplayLayout.ColumnChooserEnabled =
DefaultableBoolean.False;_grid.DisplayLayout.Bands[0].ExcludeFromColumnChooser = ExcludeFromColumnChooser.True;
_grid.Height = 150;
_grid.DisplayLayout.ScrollBounds = ScrollBounds.ScrollToFill;
((System.ComponentModel.ISupportInitialize)(this._grid)).EndInit();((System.ComponentModel.ISupportInitialize)(this._dataSource)).EndInit();
this.ButtonsRight.Add(_dropDownEditorButton);
this.AfterEditorButtonCloseUp += new EditorButtonEventHandler(MultiSelectGridCombo_AfterEditorButtonCloseUp);
/// <summary>
/// Sets data source
/// </summary>
/// <typeparam name="T">Object Type</typeparam>
/// <param name="dataSource">IList of types</param>
public void SetDataSource<T>(IList<T> dataSource)
DesignByContract.
Check.Require(!string.IsNullOrEmpty(DisplayMember), "Display Member not set before binding multi-select combo.");
var bindingSource = new BindingList<GridItem>();
foreach (var item in dataSource)
bindingSource.Add(GridItem.Create(item, DisplayMember));
_grid.SetDataBinding(bindingSource, null);
if (_grid.Rows.Count > 0)if (_grid.Rows[0].Cells.Count >= 1)
_grid.Rows[0].Cells[1].Column.Header.Caption = DisplayCaption;
In this last routine, Rows.Count always == 0, even though the data does bind correctly.
