Hey guys,
I have a grid that is bound to a list of objects and the type of one of those properties is datetime. We are using it only for the time portion. I've set the style property of this column in the grid toInfragistics.Win.UltraWinGrid.ColumnStyle.Time.
The question is, how do I show the time in military format?
thanks !
yeah it works, thanks !
You don't need an UltraDateTimeEditor, you can just set the MaskInput (or maybe it's InputMask, I always get that mixed up) on the grid column.
You are the best!
Belay Last...
Add a UltraDateTimeEditor to your form and set the MaskInput to {LOC}hh:mm and DropDownButtonDisplayStyle to Never...
On the column in question change the EditorControl to the UltraDateTimeEditor
Worked like a charm...
I don't use the built in editors so I would need mess around with it...
I will check it out in the morning unless someone from IG answers you ahead of time...
(Unless I get some time tonight but pretty smoked right now)
