320
programmatically check/uncheck tree nodes.
A Tree's nodes are: NodeStyle = NodeStyle.CheckBox;
When user checks a node, i programmatically check its child nodes, and programmatically set its parent to CheckState.Indeterminate;
tried listening to the below events:
<treeView_BeforeCheck(object sender, BeforeCheckEventArgs e)> and <treeView_BeforeCheck(object sender, AfterCheckEventArgs e)>
On both events, as i programmatically check o uncheck the boxes, the event is being raised again.
Is there a way to hold the event from firing, if the edit of check box is done programmatically?
else, is there a better practise on doing this?
thanks for suggestions,
R.
