I'm trying to export to PDF and produce the same results as we get from the UltraGridPrintDocument when printing. I can produce a PDF using the UltraGridDocumentExporter (as below), but I can't seem to control the margins, or the size of the grid (i.e. not just scaling to fit one page). Also, if I try to export a large grid I get an 'OutOfMemoryException'.
Infragistics.Documents.Report.Report report = new Infragistics.Documents.Report.Report(); ultraGridDocumentExporter1.AutoSize = Infragistics.Win.UltraWinGrid.DocumentExport.AutoSize.SizeColumnsAndRowsToContent; ISection section = report.AddSection(); section.PageMargins.Left = 30; section.PageMargins.Top = 20; section.PageMargins.Bottom = 20; section.PageMargins.Right = 30; ISectionHeader _header = section.AddHeader(); _header.Height = 80; IText rptHeader = _header.AddText(0, 0); Style textStyle = new Style(new Infragistics.Documents.Graphics.Font("Tahoma", 18), Infragistics.Documents.Graphics.Brushes.Black); rptHeader.Alignment = TextAlignment.Center; StringBuilder headerText = new StringBuilder(); headerText.Append("left text"); headerText.Append("center text"); headerText.Append("right text"); rptHeader.AddContent(headerText.ToString(), textStyle); ISectionFooter _footer = section.AddFooter(); _footer.Height = 80; IText rptFooter = _footer.AddText(0, 0); StringBuilder footerText = new StringBuilder(); footerText.Append("footer left text "); footerText.Append("center text "); footerText.Append("right text); rptFooter.Alignment = TextAlignment.Center; rptFooter.AddContent(footerText.ToString(), textStyle);
ultraGridDocumentExporter1.Export(ultraWinGrid1, section); report.Publish(@"C:\test.pdf", Infragistics.Documents.Report.FileFormat.PDF);
Help appreciated! thanks
I could not run this against the old version of Infragistics 10.3. I upgraded the solution to 11.1 and it worked correctly. There must be something different with my grid. I will do some more research. Thanks.
Hi Michael,
I have attached my sample here which uses your code. See if you get the same problem when you run my sample. If so, then this must be a problem with the version of the controls you are using.
If not, then the problem must be something else in your application like a property or event handler in your code that is not in the sample.
It would be very difficult to create a sample project at this time. When I remove the two lines of code listed below the export works correctly.
Infragistics.Documents.Report.IGap sectionGap = section.AddGap();sectionGap.Height = new Infragistics.Documents.Report.FixedHeight((float)25);
I tried out your and it works just fine for me. I did my test with the latest service release of NetAdvantage 2010.3. So maybe you are using an older version (without the latest service release). Or perhaps there is something different about your grid and mine.
If you can post a small sample project demonstrating the problem here, I'd be happy to test it out with the latest service release to see if the issue is fixed or if it's just some other factor in your application causing the issue.
Using the code below to export to a PDF file I am losing columns and the final column on the page does not fit so it is being cut in half. Currently running INF 10.3
Infragistics.Documents.Report.Report pdfReport = new Infragistics.Documents.Report.Report();#region . Add Header .ISection section = pdfReport.AddSection();IText sectionHeader = section.AddText();sectionHeader.AddContent(string.Format("Order Inquire"));sectionHeader.AddLineBreak();sectionHeader.AddContent(string.Format("Some text"));sectionHeader.AddLineBreak();sectionHeader.AddContent(string.Format("Printed: " + DateTime.Now.ToString()));sectionHeader.AddLineBreak();sectionHeader.AddLineBreak();sectionHeader.Alignment = Infragistics.Documents.Report.TextAlignment.Center;this.ultraGridDocumentExporter.Export(this.ultraGrid1, section);Infragistics.Documents.Report.IGap sectionGap = section.AddGap();sectionGap.Height = new Infragistics.Documents.Report.FixedHeight((float)25);this.ultraGridDocumentExporter.Export(this.posPaymentGrid, section);#endregionpdfReport.Publish(saveFileDialogPDF.FileName, Infragistics.Documents.Report.FileFormat.PDF);
However if I do not add the section and simply do the code below. All the columns print and are resized to fit.
this.ultraGridDocumentExporter.Export(this.ultraGrid1, saveFileDialogPDF.FileName);
Am I adding the section correctly or is the section causing the grid not to be resized?
