40
set focus in first cell of 'AddRow' in UltraGrid
Hi,                I have been struggling with what I think should be a relatively simple task.  I am trying to programmatically apply focus to the first cell in the ‘addrow’ of an empty UltraGrid with the following property set:       THIS-OBJECT.ultraGrid1.DisplayLayout.Override.AllowAddNew = Infragistics.Win.UltraWinGrid.AllowAddNew.FixedAddRowOnTop. I can make it work if the grid has some data in it, but when it is empty I have been playing with code like below with no luck:
        ultraGrid1.PerformAction(Infragistics.Win.UltraWinGrid.UltraGridAction.FirstCellInGrid).
        ultraGrid1.PerformAction(Infragistics.Win.UltraWinGrid.UltraGridAction.entereditmode).
 And:       ultraGrid1.ActiveRow = ultraGrid1.rows[0].  // trying to set ActiveRow to the AddRowOnTop…      ultraGrid1.ActiveRow.cells["paymentType"].activate().  // paymentType is the name of the column Any guidance would be much appreciated.
