2060
Chart inside a WinGrid
Is there any way to put an ultrachart in an ultrawingrid?
Ideally I'd like to show the chart in a child row, and therefore only needs to be populated when the users drills down into the data.  The data in this grid isn't consistent.   The grid sits in a form that is a generic form used to display report data.  Not all reports will use this feature.
If it is possible could you provide some sample code in VB.NET on what I need to do?
On a similar note, is it possible to add custom controls to work as stated above?
Many thanks,
Nathan
