I have a WinGrid which i want to bind to an SQL query result.
I have a dataset which contains some tables, i have an SQL query that involves some of these tables and i want to bind this query's result to the WinGrid.
I was able to easily bind a table to the WinGrid, i have tried to define a query in the XSD file, but when i click ADD->QUERY->SQL, the select with multiple rows is grayed and only the one with a single is enabled.
What am i doing wrong?
Can you help?
Thanx, Gilad.
