Check out the Style property on the column. I think there's a style for ProgressBar.
If not, you can still do it using an editor. What you do is place an UltraProgressBar control on the form with the grid and set the grid column's EditorControl property to the ProgressBar control.
The MinValue and MaxValue properties of the column determine the min and max of the progress bar.
