110
Close button with UltraTab in v7.3
Hi, I am creating a UI in where user can display new tabs and close tabs much like Firefox. I am using UltraTabControl v7.3 and found that there is no CloseButton supported on this version :-( Can anyone please provide me some guidance on how to implement close button?
  • 2334
    Support for displaying a close button in the Tab wasn't added until v8.1. However, you could use a Creation Filter to add a close button to the Tab. There is a sample in the KB that shows how to implement this for the UltraTabbedMDIManager and I assume it would be a very similar solution.
    The KB article can be found here: http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10054
    If you want to try the CreationFilter, I recommend checking the Infragistics KnowledgeBase for some articles and samples. And also, get the UIElementViewer Utility, it's a big help. see Introducing the Infragistics UIElementViewer Utility
