Normal 0 21 false false false FR-CA X-NONE X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} Here is what i want to do : I have 2 objects (see classes bellow, I also added my form code) : PartyType and Personne Personne has a PartyType property. I want to be able to databind a collection<Personne> to your grid. I want to be able to edit the PartyType of a Personne object using a combobox in the grid that would list the available type and style be databound to the underlying collection. So instead of having a textbox showing : Test.DataObject.PartyType I would like to have a combobox showing the value of PartyType.ID for the Personne object of that row. The comboBox still need to be databound to the underlying datasource.
Is this possible ?
using System;using System.ComponentModel;namespace Test.DataObject{ public partial class PartyType { private string _description; private string _id; public event PropertyChangedEventHandler PropertyChanged; public string Description { get { return _description; } set { if (value != _description) { _description = value; NotifyPropertyChanged("Description"); } } } public string ID { get { return _id; } set { if (value != _id) { _id = value; NotifyPropertyChanged("ID"); } } } private void NotifyPropertyChanged(String info) { if (PropertyChanged != null) { PropertyChanged(this, new PropertyChangedEventArgs(info)); } } }}
using System;using System.ComponentModel;namespace Test.DataObject{ public partial class Personne { private string _id; private string _nom; private PartyType _partyType; public event PropertyChangedEventHandler PropertyChanged; public string Nom { get { return _nom; } set { if (value != _nom) { _nom = value; NotifyPropertyChanged("Nom"); } } } public PartyType PersonnePartyType { get { return _partyType; } set { if(value != _partyType) { _partyType = value; NotifyPropertyChanged("PersonnePartyType"); } } } public string ID { get { return _id; } set { if (value != _id) { _id = value; NotifyPropertyChanged("ID"); } } } private void NotifyPropertyChanged(String info) { if (PropertyChanged != null) { PropertyChanged(this, new PropertyChangedEventArgs(info)); } } }}
using System;using System.Collections.Generic;using System.ComponentModel;using System.Data;using System.Drawing;using System.Linq;using System.Text;using System.Windows.Forms;using Test.DataObject;namespace Test{ public partial class Form1 : Form { private Personne _personne; private BindingList<Personne> _listPersonne; private BindingList<PartyType> _listPartyType; private readonly PartyType _personnePartyType; private readonly PartyType _CompagniePartyType; private Personne _personne1; private Personne _personne2; private Personne _personne3; public Form1() { InitializeComponent(); _personnePartyType = new PartyType { Description = "Personne", ID = "1" }; _CompagniePartyType = new PartyType { Description = "Compagnie", ID = "2" }; _listPartyType = new BindingList<PartyType> { _personnePartyType, _CompagniePartyType }; } private void ultraButton1_Click(object sender, EventArgs e) { _personne1 = new Personne { Nom = "Mathieu", ID = "M", PersonnePartyType = _CompagniePartyType }; _personne2 = new Personne { ID = "E", Nom = "Eli", PersonnePartyType = _personnePartyType }; _personne3 = new Personne { ID = "PL", Nom = "Pierre-Luc", PersonnePartyType = _CompagniePartyType }; _listPersonne = new BindingList<Personne> { _personne1, _personne2 }; grid.DataSource = _listPersonne; } private void ultraButton2_Click(object sender, EventArgs e) { _listPersonne.Add(_personne3); } private void ultraButton3_Click(object sender, EventArgs e) { foreach (Personne personne in _listPersonne) { if (personne.ID == "PL") { personne.PersonnePartyType = _personnePartyType; } } } }}
