100
Stacked Y Axes?
Is it possible to create a chart with a stacked Y axes as in the attached example?  Each series has its own little section of the Y axis.
  • 28496
     you can probably do this by creating a composite chart with multiple Y axes, setting the margins on each Y axis so it only takes up a portion of the vertical area.
    the StackedLine chart might be another solution to the problem, if that serves your purposes.
