1075
Changing Database Runtime
 Hi!
I need to change a  database during runtime.DB structure is the same but data is different.
Are ValueLists, Filters, etc. needed to be cleared manually or they are cleared automatically when I change DataSource of my grid? Is it OK to set grid.DataSource = new DataSet(); or old DataSourse needs to be desposed before it?
  • 37774
    If the structure is the same, these things should still remain intact, I believe.  As a general good practice, you should probably be doing your grid's initialization in the InitializeLayout event, since this will fire when the grid is re-bound.
    -Matt
