70
Hot Tracking priority, Empty Row settings...
I have a couple of directives from our UI team that I need to implement in an UltraWinTree control:
  1. Mousing over a 'Selected' node should not change it's appearance.  Since the priority of the HotTrackingNodeAppearance is higher that that of the SelectedNodeAppearance, mousing over a 'Selected' node causes it to be displayed with the HotTracking appearance.  I would like to implement the opposite behavior, mousing over a 'selected' node should leave the node's appearance unaffected.  I've tried doing this manually in the MouseMouse event, but it seems that the appearance objects have already been applied at that point.
  2. Is there a way to fill the unused portion of an UltraTreeView control with empty rows?  I'm looking for the same functionality implemented by the UltraGridView's EmplyRowSettings property.
