945
UltraCombo questions
 I am binding an ultracombo to an object data source and want to bind the "Text"property to a property in my object. If the dropdown style is "DropDown" the selection is showing in the combo. If the dropdown style is "DropDownList" the selection from the drop down will NOT show in the combo. I switched back and forth the "Text" property (between binding it and not) and the result is the same - depends on the drop down style to show it or not.  Am I missing a property that I need to set/reset?
As a separate question - I would like the combo to show the 1st item every single time I am entering the screen or repopulate. Again, is there a property for this or I have to handle an event that fired from the combo?
Thanks!
