1210
Problem for UltraCombo SuggestAppend property in UltraGrid.
 I am Using ultra combo in my application as a editor Control in Grid.
 I set AutoCompleteMode as SuggestAppend for that combo. If i press any key then it is not showing drop down box with possible values. But in case if I use same combo box in my from then it is working fine.
 To work Combo box in same way in grid do we have to set any property? Or it is a default behavior of ultra combo when it is used in Grids as a Editor control.
 Awaiting your solution at the earliest,
 Thanks and Regards,
 Ganesh Patil.
