80
How to improve UltraGrid's performance when using multibands?
I would like to find out a way to improve UltraGrid's performance for the following simplified use case:
- DataSource consists of a parent-child relationship, with 2 tables having 5000 records each, and an one-to-one relationship between records;
- For the first time, it will take about 1 min 40 sec, whenever you invoke grid code which enumerates ChildBand rows.
To repro the behavior, either invoke _ultraGrid.Rows.ExpandAll( true ) or run the following:
foreach( UltraGridRow group in _ultraGrid.Rows )
 foreach( UltraGridChildBand band in group.ChildBands )
  foreach( UltraGridRow item in band.Rows )  { // Some code here ... }
Thanks a lot for your help,
Horea
PS
If needed I will provide the sample code.
