i am Converting a Win grid to Excel, while converting the in to the Excel the date column in the Win Grid gets converted as a integer column, it is just showing as integer, we need to open the Excel, And do the format clees option to get it changed to Date.
Please let me know how to convert a date cloumn in wingrid to date column in excel automatically while converting.
I am having the same bug using NetAdvantage Select 2008 Vol. 3
Assembly versions are all 8.3.20083.2021
All posts I found about the bug refers to 7.X versions. Is anybody else having this bug in 8.3, like me?
Moreover I cannot access to BR27306 due to an error in your Web site ("There was a problem retrieving the bug reports. Please try again in a few minutes.").
Finally, I know there is a Service Release for 8.3, dated 01-DEC-2009 and having build version 2138, but its release notes does not mention this bug, so I did not test it.
I would appreciate any help.
Thanks.
You may need an appropriate subscription to be able to download hofixes (not sure. Contact support for this issue or may be one of the Infragistics employess will answer you here).
After that go to www.infragistics.com - view my - keys and downloads - netadvantage - select the hotfix from the list
Please let me know from which link i can download the Hotfix, I am unable to search the number you gave.
thanks a lot in advance.
You need a hotfix. See bug report BR27306
This concerns version 7.2 CLR 2.0 and 7.3 CLR 2.0
