How can I set the DropDownStyle to DropDownStyle.DropDownList for an EditorWithCombo object? The property is readonly.
You shouldn't be setting this property directly on the editor. It's actually the owner that is responsible for maintaining this information and providing it to the editor; since you're posting this question in the WinGrid newsgroup, I'm assuming you have this in a grid, which would make the owner the column. Set the Style property of the column to DropDownList; unless you're doing something like setting a DataFilter, you probably don't need to create the EditorWithCombo either (assuming you are doing so).
-Matt
