This is just to share a question posed by customer Ilan, and the resolution he found; regarding the proper location of dll's required by the CAB Extensibility Kit:
Question: I've compiled the CAB Extensibility Kit and wanted to add the items (Workspaces etc.) to the toolbox in VS2008. i chose "add item" on a new tab in the toolbox and tried to browse and point at the "C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\CAB Extensibility Kit\Source\Infragistics.CompositeUI.WinForms\bin\Debug\Infragistics.Practices.CompositeUI.WinForms.dll". However I'm getting a message box saying: "There was an error loading types from assembly 'C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\CAB Extensibility Kit\Source\Infragistics.CompositeUI.WinForms\bin\Debug\Infragistics.Practices.CompositeUI.WinForms.dll' 'Could not load file or assembly 'Microsoft.Practices.CompositeUI, version=1.0.51205.0, Culture=neutral, PublicKey Token=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.'" Can you please tell me what did I do wrong?
Thanks for your help, Ilan.
My suggestion:I would like to ask if you can find the following files in C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\CAB Extensibility Kit\Source\Infragistics.CompositeUI.WinForms\bin\Debug:
Microsoft.Practices.CompositeUI.dllMicrosoft.Practices.CompositeUI.WinForms.dllMicrosoft.Practices.ObjectBuilder.dll
If the above listed files are not present, then you may need to navigate upwards four levels and compile the solution: C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\CAB Extensibility Kit\Infragistics.CompositeUI.WinForms.sln.
Ilan's resolution:I worked some more after your clue, and what solved it was the delete the Microsoft.Practices.CompositeUI, Microsoft.Practices.CompositeUI.WinForms, Microsoft.Practices.ObjectBuilder, and re-add them again from c:\Program Files\Microsoft Composite UI App Block\CSharp\Source\CompositeUI.WinForms\bin\DebugSuddenly i was able to add the Infragistics.CompositeUI.WinForms and they all appeared in the toolbox: ImageSmartPartInfo, UltraMdiTabWorkspace, UltraExplorerBarWorkspace, UltraMdiTabSmartPartInfo, UltraDockWorkspace, UltraExplorerBarSmartPartInfo, UltraTabWorkspace, UltraToolbarsSmartPartInfo, UltraToolbarsManagerWorkspace, UltraTabSmartPartInfo and UltraDockSmartPartInfo...
All it took was to post here I guess. Even though I had all of the libraries in the same location (and I tried different locations within the search path) it still gave me the same error. Finally, I placed the Microsoft.Practices.CompositeUI libraries and the Microsoft.Practices.ObjectBuilder libraries in the GAC.
I'm having the same problem, but this solution doesn't appear to be working. Any other ideas?
Sorry, didn't mean to be too Dramatic.
OK, avatar updated...no more evil! :)
This information is so good, but you look so evil!
