I'm hoping that someone can help me understand how the Document RelativeHeight/Width are intended to work.What I'm trying to do is to create a Document section (or really a page within a section) that consists of a quadrant made up of 4 equally sized cells. Within each cell will be content that should fill that cell.What I did in an attempt to accomplish the objective was to create a section made up of a table with 2 rows each row with 2 cells.The code looks something like the followingReport report = new Report(); ISection section = report.AddSection();//* Add a table to the sectionITable table = section.AddTable();//* I don't want a header or footer on the table and want to table to fill the section so I did the following//* assuming that setting the height/width to 100% would fill the section within the page boundstable.Header.Height = new Infragistics.Documents.Report.FixedHeight(0f);table.Footer.Height = new Infragistics.Documents.Report.FixedHeight(0f);table.Height = new Infragistics.Documents.Report.RelativeHeight(100);table.Width = new Infragistics.Documents.Report.RelativeWidth(100);//* Now create the rows/cellsITableRow toprow = table.AddRow();toprow.Height = new Infragistics.Documents.Report.RelativeHeight(50);//* I assumed that setting the row height to 50 and cell width to 50 and height to 100 would create my//* quadrant of equally sized cellsITableCell upperLeftCell = toprow.AddCell();ITableCell upperRightCell = toprow.AddCell();upperLeftCell.Width = new Infragistics.Documents.Report.RelativeWidth(50);upperLeftCell.Height = new Infragistics.Documents.Report.RelativeHeight(100);upperRightCell.Width = new Infragistics.Documents.Report.RelativeWidth(50);upperRightCell.Height = new Infragistics.Documents.Report.RelativeHeight(100);ITableRow bottomRow = table.AddRow();ITableCell lowerLeftCell = toprow.AddCell();ITableCell lowerRightCell = toprow.AddCell();lowerLeftCell.Width = new Infragistics.Documents.Report.RelativeWidth(50);lowerLeftCell.Height = new Infragistics.Documents.Report.RelativeHeight(100);lowerRightCell.Width = new Infragistics.Documents.Report.RelativeWidth(50);lowerRightCell.Height = new Infragistics.Documents.Report.RelativeHeight(100);//* I then call "fill" methods on each of the cells just createdfillUpperLeft(upperLeftCell);fillUpperRight(upperRightCell);fillLowerLeft(lowerLeftCell);fillLowerRight(lowerRightCell);Stopping here for a second. Is this the proper way to accomplish my objective? If not, do I need to somehow get the page size (within the pageboundaries) in points and then create the table as fixedheight/width somehow?Now, each of the fill methods does something like the following, again assuming that the Relative height/width values relate to the cell size.private fillUpperLeftCell( ITableCell baseCell ){ ITable table = baseCell.AddTable(); table.Height = new Infragistics.Documents.Report.RelativeHeight(100); table.Width = new Infragistics.Documents.Report.RelativeWidth(100); //* What I want is for the header to be 40% of the cell/table height, the footer to be 10% and the middle 50% to contain other content Infragistics.Documents.Report.Table.ITableHeader header = table.Header; header.Height = new Infragistics.Documents.Report.RelativeHeight(40); header.Repeat = true; //* Add a cell to the header with an image. ITableCell cell = header.AddCell(); cell.Width = new Infragistics.Documents.Report.RelativeWidth(100); IImage image = AddImage(new Infragistics.Documents.Graphics.Image( myHeaderImage )); image.KeepRatio = true; cell.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Middle; cell.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Center; //* Add the footer with an image Infragistics.Documents.Report.Table.ITableFooter footer = table.Footer; footer.Height = new Infragistics.Documents.Report.RelativeHeight(10); cell = footer.AddCell(); cell.Width = new Infragistics.Documents.Report.RelativeWidth(100); image = AddImage(new Infragistics.Documents.Graphics.Image( myFooterImage )); image.KeepRatio = true; cell.Alignment.Vertical = Infragistics.Documents.Report.Alignment.Middle; cell.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Center; //* Now, add some content to the middle (the one table row that I add) //* Add 2 cells with the first being 30% of the width and the second being 70% ITableRow row = table.AddRow(); cell = row.AddCell(); cell.Width = new Infragistics.Documents.Report.RelativeWidth(30); cell.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Right; IText txt = cell.AddText(); txt.AddContent("Text in cell1"); cell = row.AddCell(); cell.Width = new Infragistics.Documents.Report.RelativeWidth(70); cell.Alignment.Horizontal = Infragistics.Documents.Report.Alignment.Left; IText txt = cell.AddText(); txt.AddContent("Text in the second cell");}So, what I expected here was that there would be an image centered in a header that was 40% of the cell height, an image centered in the footertaking 10% of the cell height and the rest filled by a row with text.What I end up with is something that does not look anything like what I expected.Can someone set me straight? What am I missing here?ThanksNeil
