I have data that is grouped like this:
...and so forth.
I'd like to style the *columns* of Group0,1,...,n based upon the values contained within on a per *COLUMN* basis. I can't see how to do this using UltraGridGroupByRow and when I set the SummaryValue and SummarySetting Appearance property - it styles the top level summary row but not the group rows themselves.
Is there a way to get to the style that is applied to specific columns of Group0, Group1 etc.?
I recommend that you Submit a feature request to Infragistics
OK - I see - thanks for confirming. Any plans that will change this? As is, I'm concerned that as the number of rows and groups grow I will have performance problems. I'd like to be able to avoid the cost of having to update every GroupByRow even if it hasn't changed since it requires some depth-wise processing to determine how to style.
OK, I see now that I have to use the SummaryValueChangedEvent to handle this situation. But now I have a slightly different problem...in general, I want to color specific columns in Group0,Group1 etc. based upon values in the child rows. However, in some cases, I actually want to style the entire row.
So far, I the only event I can find that gives me access to the entire row is InitializeGroupByRowEvent. But this only fires once so I cannot use it to update the style of Group0,Group1 when the child rows (e.g. - Row0-n) change. Is there an equivalent to SummaryValueChangedEvent that lets me have access to the entire row and not just the specific summary?
