1175
How to change appearance of current date?
is there any way to change the appearance of only the current date(not the selected date) in UltraWeekView, UltraMonthViewSingle, and UltraMonthViewMulti? Thank you, Jamie
  • 2094
    You can also use "Appearances" which is the easiest way IMHO.
    Cheers
    Aaron
                Dim AP As Infragistics.Win.Appearance
                ' Create an Appearance for each day you want to look "different"
                AP = Me.CalendarInfo2.Appearances.Add("SpecialRedDay")
                AP.BackColor = Color.FromName("Red")
                Me.UltraCalendarLook1.DaysOfYearLook(Now().Date.Appearance = _
                Me.UltraCalendarLook1.Appearances("SpecialRedDay")
  • 2094
    Investigate: Infragistics.Win.UltraWinSchedule.DayLook
     There is a fantastic example supplied on how to change Appearances of timeslots/days/weeks/appointments/months/alternate days etc
     C:\Documents and Settings\All Users\...\Samples\WinForms\WinSchedule\VB\Appearances
     If you really want to get tricky look at the following KB Article:
    Knowledge Base Article: KB05595
    HOWTO:How to use a drawfilter to customize the display of the UltraWinSchedule day and timeslot elements.
    <Link to Article Here>
     Hope this helps
    Cheers
    Aaron
  • 2765
    You can infact do it in your code by comparing current date.
