After upgrading from .NET Framework 4.7.2 / Infragistics 18.2 to .NET 6 / Infragistics 22.1 the UltraTextEditor is not consistently displaying our custom context menu. I believe this issue is the same as the one described here but that was handled with a private case so I'm unable to see the resolution.
Any suggestions would be appreciated. Thank you.
You are very welcome. Have a great day!
Thanks very much Michael, I appreciate the quick response!
ContextMenuTest (2).zip
Here is a sample we used to verify this.
Note, this particular version is accessible on the downloads page by logging into www.infragistics.com and checking the service release radio button on the right side.
Hello and thank you for contacting Infragistics. Yes, there was an issue where the context menu would inconsistently show up. The fix was to upgrade to our latest patch of 23.1 which is build 111. Please install 23.1 and if it asks to check for updates please do so and make sure it installs 111 by looking at the NuGet package version for build 111.
