20
Winform version 19 - windows 11 UI support
We have a infragistics version 19
I use visualstudio 2019 on windows 11
but I found issue that is broken UI component
So, How can I this issue fix it?
  • 2680
    According to our Supported Environments page, Visual Studio 2019 is supported for versions 19.1 and later, so that itself is not an issue. However, I am afraid that Windows 11 OS is officially supported for Ultimate UI for Windows Forms 20.2 and later, hence the specified configuration is expected to cause issues.
    My suggestion is to try to run the application on an environment having Windows 10, or alternatively keep working in the current environment by only directly updating the Ultimate UI for Windows Forms dependencies to at least version 20.2, preferably higher.
    If the issue persists in this case, please, provide more details about the "broken UI component", such as name of the component, steps to reproduce, sample code-snippets, screenshots and anything else you consider relevant.
    For upgrading, you might consider the topics under the Upgrading Your Windows Forms Projects section in our documentation helpful.
    Additionally, please keep in mind that depending on the .NET version - .NET (Core) or .NET Framework, either NuGet packages or assemblies should be used. More information about the configurations requiring NuGet packages can be found in this topic.
    In case you do go down the road of updating the Ultimate UI for Windows Forms library and do not currently have access to a newer version, please, do not hesitate to contact our sales department at sales@infragistics.com regarding acquiring a licensed version.
    Meanwhile, you could always test with the Trial version, which is always the latest one and is currently with number 23.1. It can be downloaded from the “Free Trials and Downloads” page on our website. It should be supported for Windows 11 and Visual Studio 2019 with no issues.
    Lastly, according to our Product Lifecycle page, the currently supported versions of Ultimate UI are 23.1, 22.2, 21.2. Having this in mind, version 19.2 is no longer supported and is therefore not eligible for developer support services neither is receiving any bug fixes or new development. So, upgrading your app is highly encouraged to be able to leverage all introduced enhancements since version 19.2 up until the latest.
    If you require any further assistance on the matter, please, let me know.
    Best regards,
    Bozhidara Pachilova
    Associate Software Developer
