475
Setting active UltraTree node in code does NOT highlight it
I have tried every solution mentioned on these forums, with multiple variations, and the active node is still not highlighted (with background color) when the tree is loaded.
I set the tree data source to a dataset and expanded everything, this all works great.
I then tried several variations of the below, but the node is never highlighted.
var node = ultraTree1.GetNodeByKey("5");
ultraTree1.SelectedNodes.Clear();
node.BringIntoView();
ultraTree1.ActiveNode = node;
ultraTree1.HideSelection = false;
node.Selected = true;
The active node is correct and loads my list view with the related data.  Even trying to override the back color didn't work.  When I manually select the node, it highlights properly.
