475
Only getting two levels deep on hierarchical UltraTree
From what I understand, the UltraTree control will automatically generate all levels depending on the relations you specify between two tables.
I'm creating a proof-of-concept using folders.  One table has all the folders.  The second table has the folder parent-child relationships.  All the folders are displayed in the tree, but only two levels deep.  See the picture attached.  For example, you can see how 5 should be under 4, and 7 under 5, but 4 and 5 are showing up at the root level.
Also note that it only shows the ID instead of the Name (A, B, C). Is there a way to get it to show the Name?
Here is the code to generate data in the dataset tables.
var folders = this.dataSet1.Tables["Folders"];
folders.Rows.Add(0, "Attachments");
folders.Rows.Add(1, "A");
folders.Rows.Add(2, "B");
folders.Rows.Add(3, "C");
folders.Rows.Add(4, "D");
folders.Rows.Add(5, "E");
folders.Rows.Add(6, "F");
folders.Rows.Add(7, "G");
folders.Rows.Add(8, "H");
folders.Rows.Add(9, "I");
var folderHier = this.dataSet1.Tables["FolderHier"];
folderHier.Rows.Add(1, 0);
folderHier.Rows.Add(2, 0);
folderHier.Rows.Add(3, 0);
folderHier.Rows.Add(4, 1);
folderHier.Rows.Add(5, 4);
folderHier.Rows.Add(6, 2);
folderHier.Rows.Add(7, 5);
folderHier.Rows.Add(8, 3);
folderHier.Rows.Add(9, 3);
DataRelation dr = new DataRelation("FolderHierarchy", dataSet1.Tables["Folders"].Columns["FolderID"], dataSet1.Tables["FolderHier"].Columns["FolderID"]);
dataSet1.Relations.Add(dr);
ultraTree1.DataSource = this.dataSet1;
ultraTree1.DataMember = "Folders";
